Last Saturday I had the Ontario crew out to help me with my GR4 conversion. Here is Russ, on Evans' headlight conversion, Wayne on welding detail, and Sam Civello on metal fabrication. Things are going well with the help of my Pantera friends.
  • DSCF1594_(Small)
Whos flares do you use? How do they fit? Did you measure how much wider they are front and rear over the stock fender?
I used Hall flares but they are all made by Bob Byers. The flares extend 2 3/4" in front and 4" in rear. Takes alot of balls (or lack of brains) to take a zipsaw to a perfectly good $50k car. My neighbour walked into the garage while I was cutting and said "you're f@$ked", then walked away.
Do they fit? Hell no. They are glass and can be manipulated with some physical persuasion. Good thing I'm in top shape and svealt like a cheeta. BAWAHAHAHAHA!
Paint colour? Not sure, but it will be dark. Not black. Black is the meanest colour for a Pantera but I can't live with the maintenance again.With my last black Pantera, I had to carry a rag around in my back pocket to wipe off fingerprints and I started to feel like Chachi (sp) from Happy Days.
I was going to fill in the rear exhaust holes but decided to replace the entire rear panel with a new piece.
Should be ready for paint by the end of December.
Will
Agreed, I agonized, measured then re-measured, looked at it some more, before getting the cut off wheel out. My measuring wasn't helped by the fact the car was stripped down with no suspension to use as a reference point. The flares don't go where you'd first think just looking at the two wheel well edges. But once the cutter hit the first fender it was all go from there.
Did you just screw the flares on or bond them? I'm using a product from Lord Fusor Adhesives that Bill Gaino (LPB) put me onto. Mine will be blended to the body.
Nice. Got more pictures of that car?
Now isn't it a problem painting the car with the flares bonded on? There isn't a natural place for the paint to end? It needs to bridge the gap?
Hey LPB?
Just like the red car, there will be no gap. I would expect the glue would squeeze out of the gap, get hard, be trimmed, sanded, primed and painted. Better rough it up good to start with, both sides. First you need to make sure that you have no tire rub to cause a re-crack. I have never put on flares like those. It would be easier to blend them in with the qtr, but that's a different look. I belive I would do one first before I jump all the way in. I see then attached like that all the time so there must be a procedure. WILL, Your flares don't have that little flat edge like the red car. I have attached lower side skirts with tiny headed rivets in countersunk holes, and then filled over the rivet heads.Looks like Your gonna have your work cut out for you finishing the edge where it meets the qtr.
But if you fill the ridge, even radius it to the !/4, won't the paint in that radius have the tendency to crack?
I've seen a lot of the plastic bumper covers on the new cars have the paint peel right in those ridges because the paint isn't flexible enough. Particularly the clear coat.
I don't know? I think that red car is kind of the "before" picture and I wanna see what the current or the "after" picture looks like. I think it is gonna crack and you are going to have paint the entire car to fix it and to match the color.
Check out this car at PI. Same flare as the red car, a little different than Wills. http://tinyurl.com/yhslhox Who runs their body shop? They sure were well bonded to the bare metal, and must be to not crack. Notice how wide an area was ground down on the car, and how more bonding material appears to be pushed up from underneath, this would make it attached even stronger, as it needs to be.
  • rever_rear_wreck
I don't want to sound like I'm putting these flares and systems down, because I am not.
Considering the fact that the stock steel fenders need to be cut to do this at this point I won't consider it either simply because there is no going back.
I have just had life lessens that tend to prove to me that there is always just one little drawback to something.
Well here to me it is obvious that the flares are sticking out so far that they definitely are put out there in harms way. I'm not convinced either that the difference in the materials being bonded together, steel and fiberglass, have a similar coefficient of expansion here and that a two stage paint will have the durability to survive say ten years of NY cold winters and hot summers without cracking along the obvious expansion of the bonding joint.
Anyway, kudos to all of you guys. The cars look fantastic. I hope they last forever for you with little problem.
As long as the bond holds, there should be no crack, your right to worry though, nothing lasts forever. I have these Honda young kids come to the shop with their low air dams busted all the time. I fix, replace, it is inevitable, they gonna hit something. I like the look too, but I can't cut my button car either. One thing I would do Will,since these flares don't appear to have the square edge, is to at least block the very edge flat where it meets the body, so that the flare starts of 90 degrees from the qurtr panel. You don't want it tapered thin to the place where it meets the body. You can fill any air pockets that appear in the edge of the 'glass after you flatten it, but before you bond it. It will be thicker than the tapered edge, and stronger. Note the above pics. Pay careful attention when you make the bond, clean, dust free, 60-80 grit scratches, warm temp. Let it ooze out and trim before it fully sets, let it firm up yet still a little flexy. Make yourself a very small sanding block, maybe the size of a box of matches. Your gonna need it when you start sanding up to the edge of the squared flare.
Adhesive science has come a long way in the last number of years. Most new cars use panel adhesives now. If you bond 2 pieces of 20ga metal together, you will tear the steel before the bond releases.
When the flare is mounted with the adhesive, I'll use nuts and bolts to fasten until the bond sets. The flare lip with be trimmed and sanded before installation. When the excess bond gets squeezed out from the lip, I'll simply run my finger over the lip, just as you do with caulking to remove the excess and give it a clean smooth finish. I don't plan on doing any sanding around the lip after it sets. Then I'll remove the nuts and bolts and fill the holes.
Will
Not a Pantera, but still a Ford.. This car I built some years ago got fiberglassfenders attached to the steel. It worked just fine. After I cut away the fenders in a similar way to what 4NHOTROD have done, I extended the rear inner fenders out til the fenderopening, and welded them making for one sturdy place to attach the flare. In front I made a bead of about 1/3" in the fender to stiffen it, and I used epoxy to "glue" the flares in place. Roughed up the paint and fiberglass, and screved it together so it would sit where it was supposed to do while curing. Bonded over the holes when it was cured, and the flares survived with no cracks a good "bit" of spirited driving on some twisty roads around where I live.
  • minescort
Originally posted by David B:
Looks mean, Will. Let's see it with the wheels on!
Hey Doug, my original GT5 has fiberglass flares mounted to steel. Not sure how it was done back then, but I never had a crack in all these years. And these flares have taken a beating. Pretty tough too.
They must be pretty thick. I'm sure that the factory knew what they were doing. They really hang out there exposed to just about everything.
If the original fenders didn't have to get cut up I'd be much more comfortable with this conversion.
Don't get me wrong. I thing the cars look great. I guess I'd be better off buying a GT5 already done so I don't have to be so wimpy about the entire process?
I sure it's gonna come out great Will. Carry on. Wink
David,
I am reliably informed that #9178 (and a few other early GT5) came from the factory the way it is today with the fiberglass flares blended to the fenders and not showing any discrete 'add on' line.
On the subject of cracking, I have had a few cracks in the front flares, but not at the join, simply because the suspension is set so low the tire has hit the flare a couple times.
The GT5S cars have all steel fenders, so are 'blended' by nature of the steel being a stamped panel.
