I looked at a number of cars all over the country during business travel. I was leaving on a two hour drive to see a more local car when this one appeared (from no-where) in my local paper's classified section; and it was directly on my route. Turns out, my car was living a mere 60 miles from me. It was a very solid 74 US GTS with 14.5k on the odometer and priced in the "grab your wallet now” range. I bought it on the spot. That was in July of 1999. It was off the road from 2003-2006 but has been logging miles ever since.
Pantera Upgrades and Mods
Engine
427 CI, 4.125” bore by 4.000” stroke. Built by Lenard Vastholtz.
9.5” deck Dart Iron Eagle Siamese block, 4.125” bore, Cleveland main journals, four bolt mains on all five caps, center three mains splayed.
Brodix BF301 aluminum high port heads, 196cc intake runner, C302B port and mounting locations, 67cc combustion chambers. Light port and bowl work. REV stainless valves 2.19 intake, 1.67 exh, Crane spring kit 96870 with 134lbs closed, 368 lbs at max lift.
Custom pistons, full floating pins, dished to mirror combustion chambers on heads and yield 10:1 compression ratio.
Lentz rods, 6.2, .927 pins, 2.100 journal, 7/16” Carr bolts.
4340 forged steel crank, Cleveland mains, 4.000” stroke, and 2.100” journals
Crane hydraulic roller: PN 449601. Grind Number HR-224/339-2S-12. See cam card.
Crane hydraulic roller lifters
Comp cams Magnum stainless steel roller rockers 1.7 ratio.
ARP rocker studs.
ARP head bolts.
Custom 3/8 push rods
MSD Pro-Billet distributor with Crane gear for roller cam, and 6AL box.
MSD 9mm plug wire kit.
Pantera Performance 10 quart aluminum oil pan and pick up, windage tray, baffled, hinged trap doors, scraper.
Blue printed Melling oil pump.
Electric fuel pump, regulator, Mallory
FMS M-9424-C351 intake.
Holley HP 750
McLeod aluminum flywheel
Romac stainless balancer. 28 oz standard balance.
Weiand high flow aluminum water pump
March billet aluminum pulley set.
PPC ceramic coated headers 2” primaries, custom collector.
2 ½” mandrel bent tail pipes and stock GTS style mufflers. Black ceramic coated.
Drive Train
Forged rear axles with hardened retaining nuts
Rear uprights converted to tapered roller bearings
Spicer half shafts and u-joints.
McLeod Street Twin dual disc clutch and aluminum flywheel.
Transmission and Shift Linkage
ZF safety wired, stock gearing.
PPC Stainless shift rod and spherical rod end for trunion support.
Cooling
Pantera Performance Ron Davis aluminum radiator with, twin sucker fans on plenum and lay forward kit.
Stainless tubes, pressure tank, overflow tank, and billet aluminum tank caps.
Pressure tank relocated for header clearance.
Custom stainless tubes and brackets such that short straight sections of Gates Green Stripe connect all.
Fire wall mounted heater core isolation valves and braided stainless plumbing.
Suspension
Adjustable rear upper A-arms with upper heim instead of standard ball joint.
Lower rear and all front a-arms re-welded for strength, grease zerks added at all bushing, stripped and powder coated black.
Black anodized adjustable DeTomaso wheel house brace.
Bump steer added to front uprights and zinc plated.
Camber lock kit added to front upper a-arms.
Steering wrack rebuilt with bronze bushing.
Urethane bushings in all arms.
Greasable shafts in rear uprights
Aluminum bodied adjustable Koni shocks custom length and travel for lower ride height. Springs: 550lb/in rear, 450 lb/in front.
1” chrome sway bars front and back with spherical bushings, billet caps and billet DeTom rear sway bar mount.
Brakes
Wilwood Superlight, four piston, calipers and braided stainless flex lines on all four corners.
Heavy ventilated curved vain rotors on all four corners, aluminum hats
PPC mechanical parking brake kit on rear.
SVO 1.125” bore dual reservoir master cylinder.
Wheels and Tires
Polished Kinesis K29s, 19”x 13” (6.5" backspacing) rear and 18” x 9.5” (5" backspacing) front.
Michelin Pilot Sport Rubber, 345/30/ZR19 Rear and 265/35/ZR18 front.
Body & Engine Compartment
Steel GTS flairs replace pop riveted stock GTS flares.
Seems welded/filled and smoothed.
Lead removed and welded with reinforcing in rear tail light sections prone to cracking.
L bumpers removed, holes filled with sheet metal and Euro bumpers installed.
Quad headlight conversion kit
Window mounted rear view mirrors.
Engine compartment spot welds filled and smoothed, painted satin black.
Jack plate reinforcement on rear cross member
Removable cross member for easy oil pan access
Rotary AC compressor
AC hoses re-routed through wheel well.
Stainless steel firewall and gas tank shield with foil back sound suppression mat.
Gas tank exterior media blasted and painted. Pristine interior, no sealer required.
Undercarriage stripped, painted black, and detailed. –No undercoating of any kind on the car.
All trim powder coated black.
Group IV tail lights.
Added a third brake light (look closely above the air cleaner it’s there).
Interior
Crow five point harnesses.
New headliner.
Removable Momo steering wheel
Otherwise, bone stock.
Images (18)
  • pantera1
  • panengin
  • DSC00708
  • DSC00714
  • DSC00711
  • DSC00719
  • DSC00718
  • DSC00721
  • DSC00722
  • DSC00724
  • DSC00725
  • DSC00727
  • kinesis_Wheels_and_Pilots
  • Quadlight_closeup
  • Coffield_Underside_36
  • DSC00707
  • Pantera_Profile
  • Pantera_and_GT40
Panterror,
You've done an excellent job, car looks awesome and thanks for taking the time to post. It's great to see other owners transformations and yours is certainly worthy of the attention.
Like the license plate BTW....I have it Nevada style!
Thanks for the kind words gents. As I’m sure you can all attest, it takes a fair investment of time and money. People ask me how much I have in it. I have all the receipts thrown in a box but who’s counting? Don’t really need to know. It’s only relevant if you’re selling, and that thought hasn’t even crossed my mind. You’d have to pry the keys from my lifeless body :-).
I did a lot of the mechanical and detail work but I certainly have to give credit where credit is due. I don’t have the time to do it all any more, but gainful employment has its upside as well. As I’m sure many of you can tell it was in the hands of Dennis Quella for a good while. He executed what I asked very well in regard to the body work. The fit and finish is top notch and must be seen to be fully appreciated. The first rock chip is gonna draw profanity, but it must be driven like it was meant to be!
The Kinesis wheels are a signature of sorts for Pantera Performance Center. At first I wasn’t that keen on them, but they really grew on me and I’m glad I went with them. As lengthy as my mod list is there are tons of details I didn’t list. That’s sort of fun because you know they’re there. It became sort of an obsession while it was under construction. Is it just me?
Now it’s just a plain blast. Looks are great but it’s got to drive as good as it looks. I’ve been tweaking the shifter linkage a bit. Behaves well cold but tightens up a bit after some spirited driving. Need to dial that and the suspension in. I have a lot of fine tuning but so far, I’m pleased with the cam. It’s pretty well behaved, mild lope, and pulls up from 800 rpm idle very nicely. 3-6krpm is what you’d expect. Just hope it’s enough the when the IR EFI goes on. If not, what’s a new bump stick after all the rest? I’ll have to find the dyno sheet and post it. At the moment it’s hard to keep from smiling boys. Good luck to all on your projects and hope to see them here in the gallery.
Kelly
