Sent multiple messages. Not sure what the deal it.
Never heard back.
Originally posted by HockeyDude:
All,
I'm looking at a big career change in the next couple of months if everything goes as planned, as such, I need to free up some capital.
Below is a list of Pantera parts I have cataloged. Please PM with offers for parts, will discount for bundles and for pick up (I'm located in Manassas Va, ~40 mins west of DC). I can get pictures of items that people are interested in.
Also have various Z06, LSX, renegade hybrids and GTO (2004-2006) parts. Just ask depending on if you're looking for stuff. I can email you this list too since it didn't copy/paste very well.
Dave
Pantera Items for sale - 9/14/14
1. Two Pairs of Pantera Seats
a. One pair in good shape, one pair needs recovering (sorry looked at it again and it can’t be saved, vinyl is split)
b. “good” pair
i. has working seat tracks – rollers are round.
ii. Black vinyl with black cloth center inserts
iii. Seperable Back, with Head rests
iv. Price: 350
c. “poor” pair
i. Fixed Back seats, with headrests
ii. Poor pair: 100
2. Luggage Tub – good shape
3. Interior soft pieces
a. Aft Console
i. Vinyl has shrunken as one would expect
b. 2 Door arm rests
c. 2 door panels (Not quite matching set, upholstery is slightly different.
i. 75 for both
d. Upholstery for console and early 71 dash removed in one piece in order to be usable as a template:
i. Price: 25
e. Seat Belt Retractor and panel assemblies for rockers
i. Need refinishing and new belts couldn’t hurt
4. Gauge & Switch Items
a. All Stock Gauges
i. In good shape, worked upon removal from car
ii. Speed and Tach plastic inserts for early 2 pod dash
a. Good shape
b. Console Gauge & switch plate
i. Most switches in good shape
1. All work when removed from car
2. Courtesy Light:
3. Dimmer:
4. Gauge Panel:
a. Chrome is ~75%, minor spotting started, one corner is beginning to debond from panel,
5. Hazard Switch- Works
a. Early style with zillion contacts in the back, and no hazard symbol
b. Price: 100
6. Wiper Switch Early, rotary style (Not illuminated)
a. Some damage to plastic from frozen pin
b. Price: 50
7. Thermostat Swtich
a. Gone MIA
8. AC/Heater Levers with Swich plate Face, and backing, and cables (the whole assembly)
a. Chrome and switch plate in OK condition, looks normal for car of this age, but far from concourse
b. Price: 75
5. Stock Wiring Harness and Fuse Box
a. Comes with Passenger footwell fuse Box and box guts
b. Ballast wire burned out, secondary wire run to bypass it. Other than the ballast wire, condition is pretty normal for a car of this age
c. Price: 175
6. Evaporator Assembly
a. Coil seems to be OK – non stock Evap fittings, joints covered with what looks like epoxy pipe putty – def looks like hack job
i. Did not leak when charged, but not charged for very long
b. Heater valve, its modified, don’t ask me what was done
c. Thermostat and switch control panel
7. Condenser
a. Stock condenser/shroud/motor assembly – all worked upon removal
b. Price: 130
8. Suspension/Brakes
a. Stock rotors, good shape
b. Stock calipers- good shape
c. Stock coils/shocks
d. Upper rear a-arms good shape:
i. Price: 80 for the pair
e. Steering Rack – free - after I finish mocking up new custom rack
i. No play, bushing good
ii. One inner ball joint seized
f. Stock parking brake items
i. Handle Assembly
ii. Bracket (cabin and under engine)
iii. Cables
g. Brake Master and vacuum booster – hall units
9. Drivetrain
a. Exhaust
i. Hall Headers
1. Need refinishing
ii. Mufflers – stock
1. Need refinishing
b. Accessories
i. Sanden Rotary Compressor and adapter for pantera
1. V Belt Pulley
2. Used < 1000 miles
ii. York Compressor (stock)
1. Needs rebuild –rumbling during use -
iii. Stock water pump, alternator, starter – all free (just come pick it up)
1. All worked upon removal
c. Mod Motor Mounts
i. From Wilkinsons Pantera, New In Box
d. Wheels
i. Stock wheels/tires
ii. Hall wheels (15”) – Turbine wheels??
10. Cosmetic
a. Rear Pre-L bumperettes
i. Good shape
1. Gone MIA, they’re somewhere I’ll find them
b. Side Markers – front and rear
i. Good shape
ii. Price: 50 Each
c. Emblems:
i. “Detomaso” script emblem
1. Chrome in good shape, needs some minor up
a. Looks like a sloppy job with trim adhesive after last repaint, but it flakes off on all the paces I tried
2. 1 alignment tab broken about 50% off, but will still work just fine. No damage to the other 2 tabs
ii. “Pantera” Script
1. MIA
d. Chrome trim
i. Chrome in good shape
ii. Drip Rail Trim, includes roof and A pillar peice
iii. Driver and Passenger side Chrome Trim for Door Window
1. Passenger side is bent
e. Stock headlight trim rings in good shape
i. Includes buckets, wiring pigtails, everything
f. Hood Latch’s
i. Front and rear
ii. Interior bonnet release handle:
1. Comes with Cable, handle has some relatively deep knicks
g. Aftermarket Kick panels
i. Have ~90s era speakers installed, kick panels are cut
ii. Price: 10 each???
h. Front Bonnet Grills (aftermarket)
i. In good shape
ii. Plastic
iii. Hall Units?
iv. Price: 125 for the set?
i. Delta Wing with mount brackets
i. In good shape, comes with aluminum end caps, and support brackets (for underside of decklid). Painted white
ii. Has minor stress cracks on uprights, easily fixed during color change
iii. Upright to decklid gaskets are deformed, and oxidized/discolored slightly (look tan vs white).
iv. Price: 400
11. Cooling
a. Hall Phoenix Radiator
i. Re-cored – used less than 1000 miles
1. Might have slight leak in core – Unsure
ii. Has 2 temp sensor ports
iii. Adapted one large 2400 CFM fan, hard mounted to radiator
1. Used less than >1000 miles
b. Stock cooling/surge tank
i. Repaired- no leaks
1. Used >1000 miles
c. Hard pipe replacement for Waterpump Hose
d. Stock heater Hard Pipes (Ones that run through the cabin)
i. In good shape – no leaks
12. Various
a. Parts of stock headlight lift assembly
i. Bar and gear assembly
ii. Solenoids
iii. Motor assembly
b. Golf Mark 1 Rocker Panels (pair)
i. Very close to Pantera Rockers
ii. Good for replacement of portions of rockers, but not for an entire rocker replacement.
c. Stock engine bulkhead (metal)
d. Rear Splash Guards (Left and Right)
i. Need Repainting
e. Ballast Bracket
i. Bracket which holes ballast on firewall
f. Throttle Cable tube (Through cabin)
g. Multiple other parts - ask
b. 2 Door arm rests
i. 75 for both
do you still have the part listed above? if yes,
how much thanks Mr. Lizalde
i have a 72.
All,
Dave
b. “good” pair
iv. Price: 350
c. “poor” pair
ii. Poor pair: 100
a. Aft Console
b. 2 Door arm rests
i. 75 for both
i. Price: 25
a. All Stock Gauges
a. Good shape
2. Courtesy Light:
3. Dimmer:
4. Gauge Panel:
b. Price: 100
b. Price: 50
a. Gone MIA
b. Price: 75
c. Price: 175
7. Condenser
b. Price: 130
i. Handle Assembly
iii. Cables
9. Drivetrain
a. Exhaust
i. Hall Headers
1. Need refinishing
1. Need refinishing
b. Accessories
1. V Belt Pulley
c. Mod Motor Mounts
d. Wheels
10. Cosmetic
i. Good shape
i. Good shape
ii. Price: 50 Each
c. Emblems:
1. MIA
d. Chrome trim
f. Hood Latch’s
i. Front and rear
i. In good shape
ii. Plastic
iii. Hall Units?
iv. Price: 400
11. Cooling
1. Used >1000 miles
12. Various
ii. Solenoids
iii. Motor assembly
i. Need Repainting
e. Ballast Bracket
Mr. Lizalde
i have a 72.
All,
Dave
b. “good” pair
iv. Price: 350
c. “poor” pair
ii. Poor pair: 100
a. Aft Console
b. 2 Door arm rests
i. 75 for both
i. Price: 25
a. All Stock Gauges
a. Good shape
2. Courtesy Light:
3. Dimmer:
4. Gauge Panel:
b. Price: 100
b. Price: 50
a. Gone MIA
b. Price: 75
c. Price: 175
7. Condenser
b. Price: 130
i. Handle Assembly
iii. Cables
9. Drivetrain
a. Exhaust
i. Hall Headers
1. Need refinishing
1. Need refinishing
b. Accessories
1. V Belt Pulley
c. Mod Motor Mounts
d. Wheels
10. Cosmetic
i. Good shape
i. Good shape
ii. Price: 50 Each
c. Emblems:
1. MIA
d. Chrome trim
f. Hood Latch’s
i. Front and rear
i. In good shape
ii. Plastic
iii. Hall Units?
iv. Price: 400
11. Cooling
1. Used >1000 miles
12. Various
ii. Solenoids
iii. Motor assembly
i. Need Repainting
e. Ballast Bracket
Hello, wondering if you still have the following items from your part list?
Hall Headers
Mufflers – stock
i. Handle Assembly
iii. Cables
Stock Air Cleaner
Thanks Tom
hockeydude posted:
All,
Dave
b. “good” pair
iv. Price: 350
c. “poor” pair
ii. Poor pair: 100
a. Aft Console
b. 2 Door arm rests
i. 75 for both
i. Price: 25
a. All Stock Gauges
a. Good shape
2. Courtesy Light:
3. Dimmer:
4. Gauge Panel:
b. Price: 100
b. Price: 50
a. Gone MIA
b. Price: 75
c. Price: 175
7. Condenser
b. Price: 130
i. Handle Assembly
iii. Cables
9. Drivetrain
a. Exhaust
i. Hall Headers
1. Need refinishing
1. Need refinishing
b. Accessories
1. V Belt Pulley
c. Mod Motor Mounts
d. Wheels
10. Cosmetic
i. Good shape
i. Good shape
ii. Price: 50 Each
c. Emblems:
1. MIA
d. Chrome trim
f. Hood Latch’s
i. Front and rear
i. In good shape
ii. Plastic
iii. Hall Units?
iv. Price: 400
11. Cooling
1. Used >1000 miles
12. Various
ii. Solenoids
iii. Motor assembly
i. Need Repainting
e. Ballast Bracket
PM sent
