Originally posted by Simon:
Hi, is it possible to mount a Pantera engine into the body with the 180" headers mounted on the engine and ZF? Or must be dismantled the headers first?
thanks
Simon
Not sure- there are several styles of 180s. One uses two individual pipes, one on each side, with the other pipes grouped in threes, to make completing the set of 4 on each bank easier. Another has all 4 on each side as a welded set. Do you actually have a set of 180s yet?
