I'm looking for a blown 351C for a mock-up project this season. I need the block, crank, heads, and water pump. If any one has one or all of these pieces, please contact me.
A motor that needs rebuilding will also do.
Anybody have a block that has been bored .030 or higher and can no longer be used? One that is cracked or has a hole in it is fine. How about a spun bearing that destroyed the crank or a cracked crank? Cracked heads will do the job. Have a leaking water pump headed for the garbage? I can use these parts.
Again, these parts are for a mock-up so I have minimal down time with my Pantera. They are NOT going to be used for a rebuid of any kind.
Any help would be appreciated. The closer to CT, the better! Thanks.
Michael
