I have significant play or free travel in the tie rod end, passenger side only, not in the joint end, but inside the bellows on the rack. The movement is front to back or the length of the car direction.
Any hints on this problem before I do exploratory disassembly? What type of joint connects the external rod to the rackgear underneath the bellows? Thanks in advance.
