More info:
Car S/N is 1306. Always a So Ca car.
I was told when I bought it that it was one of the first into the country. Ford did some crazy after sales stuff to the car like fiberglassing the gas tank due to a safety issue. I think the only non stock item on the car is the radiator and the carb. I do have the orignal radiator and carb.
This car has the original "flat" rear deck also.
Regards
JohnG
Originally posted by Throttle man:
I have #1303. If you look under that fiberglass on the fuel tank, you will find an Aluminum gas tank like mine.
Greetings
Thanks for the 'shout-out'. I talked with the former owner and he said the work was done by Ford and 'gratis' too.
Take care
JohnG
