I need to remove my pantera for the garage it's been in for 15 years. I needs to rise up a rather steep slope. The car will have to be pulled from behind. it's a 1971 pantera. So my Question is where is the best and safest point to attach the towing hookes and cables to do this? Thanks for any advise on this topic.
Use the subframe to the max extend possible. If you need a good angle because of the incline, remove the mesh engine screen and pass the tow line through this area. Go slowly and make sure your line doesn't touch the body. Also, though tempting, do not use any suspension points (a-arms).
