Can anyone with Geese out there give me the tire sizes that you're using? I just got dropping my front end (the previous owner had it jacked up sky high) 4.5". I think that he mounted large tires to fill up the front fenderwell space. I have 235x60x15 in front and 275x60-15 in the rear all on stock rims. Now that I've dropped the front, I'm having some fenderwell rubbing. The tires have age cracks so I have to replace them anyway so I'm looking for the right size. Thanks in advance.
Dennis:
1969 Detomaso Mangusta Specifications
price $11 150 USD
engine V8
valvetrain OHV
displacement 4949 cc / 302.0 cu in
bore 101.6 mm / 4.0 in
stroke 76.2 mm / 3.0 in
compression 10.0:1
power 171.5 kw / 230.0 bhp @ 4800 rpm
hp per litre 46.47 bhp per litre
bhp/weight
torque 420.3 nm / 310.0 ft lbs @ 2800 rpm
drive wheels Mid Engine / RWD
body / frame Steel & Aluminum
front brakes Girling discs
f brake size 298 mm / 11.7 in
r brake size 279 mm / 11.0 in
front wheels F 38.1 x 17.8 cm / 15.0 x 7.0 in
rear wheels R 38.1 x 19.0 cm / 15.0 x 7.5 in
front tire size 185-15 (70 series assumed)
rear tire size 225-15 (70 series assumed)
steering Rack & Pinion
weight 1383 kg / 3049 lbs
wheelbase 2499 mm / 98.4 in
front track 1402 mm / 55.2 in
rear track 1458 mm / 57.4 in
length 4265 mm / 167.9 in
width 1844 mm / 72.6 in
height 1069 mm / 42.1 in
transmission 5-Speed Manual
gear ratios 2.42:1, 1.47:1, 1.09:1, 0.958:1, 0.846:1
final drive 4.22:1
top speed 189.9 kph / 118.0 mph
0 - 60 mph 7.0 seconds
0 - 100 mph 19.1 seconds
0 - 1/4 mile 15.1 seconds
Smiler
I run 275/60's in back (TireRack told me these tires were designed for the Chevy 454 SS pickup) and 215/65's in front. The fronts rub on full lock, but only a little. The front looks just a little high to my eye, but I don't really want it any lower. I could raise the rear, but that would raise the rear roll center, which van Vaulkenburg and others have said is already too high.
