I have had my share of electrical problems as have most of us. Michael Shortt told me his recent electrical problems vanished after installing the replacement fuse panel from Pantera Electronics, Jon Haas. SObill Taylor raved about the panel and installation is really simple in an hour or two, depending on how many breaks you take.
What a beautiful piece of engineering! this is state of the art. It is a shame it is hidden behind a panel. The instructions and pictures are great and easy to follow, almost like connect the dots. I spoke with Jon before buying the panel and learned of his passion for Panteras and his desire to build affordable units. Jon also owns a Pantera! The ATO Fuse Panel is specific built by Jon for the Pantera. It is not a retro-fit. It is what I consider to be a plug-n-play unit. You don't cut wires!
If you blow a fuse, an LED lights next to the blown fuse. I should have done this years ago.
Here is the link: http://mysite.verizon.net/vzesb3ri/panteraelectronics/id7.html
Indy Dave
I just finished installing the ATO Fuse panel by Pantera Electronics/Jon Haas. What a beautiful piece! Jon is a master of designing and manufacturing high-quality, well-engineered electical systems for Panteras. His instructions are IDIOT-PROOF. I too have the headlight controller installed in my car. If reliability is what you're seeking in your Pantera's electrical system, go no further than Pantera Electronics.
www.pantera-electronics.com
TIP: The wires to the TWO-FUSE panel for the power windows on my car were very short and couldn't reach the ATO Fuse Panel. While you are picking up the 4-#10 female spade connectors, by some 10 GA wire and a box of butt connectors.
Swen
Jon is a straight shooter and offers the real deal. I am incorporating many of his products into my build. They include the ATO fuse panel, headlamp controller, console switch controller, and his LED tail lamps. I am installing four HID headlamps on the car, and he was able to modify the headlamp controller to keep all of the HID's on hi beam, while leaving the lo beams on while the headlamps are on at all times.
If you are looking for something that is made to fail from Taiwan that costs $20, then go elsewhere. If you want the best that American engineering can offer for the best high quality products, then Pantera Electronics is your one stop shop. The other thing that makes Jon's electronics great is that he has engineered them especially for the Pantera and the Pantera only. The fit to our quirky cars is the best, bar none.
I could go on and on -- you really will be satisfied and one cannot go wrong. Can all of these posts be made up? Don't think so.
I just installed the ATO fuse panel this weekend, and couldn't be more pleased. My electric fans are working again Smiler This was the first addition I made to the car and think this is something every Pantera owner should upgrade to. I looked at the stock unit, and it looked like the contacts had been repaired at some point. Get rid of those electrical gremlins! Jon makes a quality product, and I will definitely be back for more.
Jon is considering making up a 16-way fuse panel like his present 14-way, for owners of later Pantera's.
If you are interested in purchasing one of his works of art, or if you might plan for this update over the winter months, send Jon an email or post in this forum.
Ultimately it will hopefully drive the price down, allow Jon to plan his resources and possibly give you "14-way fuse panel guys", an upgrade path if you want to add 2 additional fuses to your wiring.
A suggestion- Larry Stock at PPC-Reno sells both a replacement ATO fuse panel and- since 2007, a 2-ATO-fuse panel to accept the two lower fuses mounted separately on L-models and late models. I think his 2-fuse panel isn't expensive and its identical in size to the stocker so mounting should not be a problem. That might be simpler than completely changing your present hookup.
