1971 Detomaso Pantera For Sale.
Serial Number: THPNLL01537
Mileage: 68,467
Price: $32,500
Contact: maddaddy (at) verizon (dot) net
Exterior:
•Original, straight and complete stock body/trim
•Factory “medium blue” paint
•Euro Group 4 taillight assemblies/lenses
Interior:
•Dash unmarked and original
•Hall high-power bulbs in all gauges
•Hall sun visor Perma Locks
•Hall accelerator pedal
•Original seats, some wear on driver’s side
•Original carpets, some wear on driver’s side
•New window whiskers/channel rubbers
•Brass window gears
•Bosch window switches
•Speakers in door panels
Front trunk:
•Hall/Ford brake master cylinder
•CNC big bore clutch master cylinder
•Lay-down radiator
•Stainless steel coolant pipes
•Rebuilt headlight mechanism
Rear trunk/engine:
•Original undercoating intact
•Early style aluminum fuel tank w/factory fiberglass wrap
•Hall extended fuel filler neck
•Stainless hose from tank to pump
•Stainless coolant and overflow tanks
•Stainless coolant pipes
•Shut-off valves in heater hoses
•Holley 600cfm carb, vac. secondaries
•Edlebrock Performer intake
•Weiand aluminum high performance water pump
•Hall Big Bore headers and mufflers
Transaxle:
•Dash-1 ZF #1956
•Late style (Dash-2) factory side mounts
•New (stock) clutch (April ’08)
•New (stock) starter (April ’08)
•Stainless steel long-throw clutch slave cylinder
•Braided stainless clutch slave hose
•Top fluid fill plug
•Side mount fluid level dip stick
Suspension/brakes:
•Braided stainless brake hoses
•Porterfield R4S brake pads
•Hall rebuilt, cad plated/powder coated rear calipers
•Stock shocks, springs and anti-roll bars
•Rebuilt steering rack w/bronze bushing
•7” and 8” Campys, powder coated
•BF Goodrich Euro T/A in 225/50HR15 front, 305/50HR15 rear
Notes:
•3 owner, Southern California car
•Gates Green Stripe coolant hoses
•Original space saver spare
•Original tool bag/jack
  • threequarteraerialcrop
