The Hawaii "Paradise Pantera" 4 owner 1973 L with 27,524 original miles. Rust free, always kept in a closed garage and never driven in inclimate weather. This car has always been loved, well cared for and is full of upgrades. Totally reliable, never a hint of problems, it runs cool, never above 195 degrees even with the A/C on in traffic. A/C blows cool! This car is not a show trailer queen but is in very good condition and has been featured in Pantera International Magazine and POCA Profiles.
The drive train was recently pulled out and the engine bay, fuel tank area were all scraped of undercoating and painted. The fuel tank was in excellent condition and was also repainted. There was no hint of rust even in the hidden areas where it usually shows up. The engine was totally regasketed, painted and flywheel, clutch disc and pressure plate replaced.
Exterior
Pantera East Campy clone wheels 17"x11" in the rear with 335x35x17 Michelin Sports and 16"x 8" fronts with 235x35x16 Hankooks
Urethane/graphite bushings
Chromed rear sway bar with billet caps
Stainless Steel A-Arm covers
Rare Mindtrain rear window louvres
Brakes/Clutch
Wilwood superlight brake calipers and slotted discs front and rear. SS hard lines and braided SS flex lines. American master cylinder upgrade.
Just overhauled CNC clutch master cylinder
Just installed Fidanza aluminum flywheel
Just installed Hayes modified pressure plate and clutch disc
New oilite bronze pilot bushing
New throwout bearing
Long throw slave cylinder
Braided SS clutch line
Engine (most bolt on parts have 2,000 miles on them)
Original 351 Cleveland 4 bolt main stock short block. All gaskets have just been changed on the engine.
Edelbrock aluminum heads modified by DSC Motorsports 4V sized valves added, bowl blended. Everything new on heads.
Edelbrock Air Gap intake manifold
750 cfm Holley mechanical secondary carb prepped by the "Carb Shop" in California
Pushrod guide plates
Double roller timing chain
Harmonic Balancer
Water pump
Roller rocker arms
Roush pushrods
Comp Cams 262H xtreme energy cam
Aluminum logo valve covers
New PPC jet coated headers
New high torque starter
ZF Transaxle
Recently safety wired and regasketed
Oil changed every 1000 miles or 6 months
home polished case
home polished side mounts
Electrical
MSD ready to run distributor
MSD 6AL ignition box
MSD Blaster 2 coil
MSD RPM switch
MSD Tach adapter
Electrical Relays installed to take load off the switches
Cooling System
Hall radiator
2 Meriah fans
Polished Stainless Steel cooling pipes
NAPA Gates hoses
Stainless steel water bottles
Tefba coolant filter
Other
New rotary A/C compressor
New high CFM A/C compressor fan
Polished aluminum adjustable camber bar
Water/alcohol injection kit
Auto meter gauges
MSD wideband air fuel mixture gauge
Taurus window motor conversion
See and hear it at these websites:
http://www.home.roadrunner.com/~dyogi/page7.htm
http://www.youtube.com/watch?v...feature=channel_page
For more information, email me at: dhyogi@gmail.com or call (808) 551-2426. This car is located in Hawaii. I recommend, encourage and welcome a vehicle inspection before bidding or purchase. $38,000
Images (9)
  • tantalus1
  • tantalus2
  • tantalus3
  • punchbowl
  • holo1
  • engine1
  • engine2
  • clutch
  • carshow
Originally posted by Mark Charlton:
Congratulations Dennis.
I think someone got a great deal on your car. I hope you are not leaving us completely!
Never, I have made many life long friends here and plan to be around whether I own a Pantera or not. I have learned a lot over the past 5 years of ownership of 3 cats and a goose and will always be willing to share what I have learned.
