Have a standard bore 351C short block assy (Block, crank, rods, pistons, cam), dated 1975! D2AE-CA casting must have been a replacement block as the serial number stamped in it is for a 1974 car! Automatic equipped so crankshaft thrust surfaces stand to be in great shape. Has been sitting for some time, and there is some surface rust in some exposed portions of some of the bores. Good for a rebuild project!!!
Short block has been sold. Thanks.
$350 as is, where is. Located in Santa Clara, CA.(55 miles south of Golden Gate bridge...)
Also have a bare set of 351C closed chamber heads, 1970 I believe. $250, look to have never been cut excessively.
Two original cast iron intakes, square bore: $25 each, one dated 1970, other 1971.
Thanks for looking!
