Finally installed engine. Still need to hook up vacuum lines and sort out ignition wires. Waiting for a custom made aluminum water tube with A/N fittings from thermostat housing to lower water tube. Once it's all put together, one final inspection and it'll be ready for engine start.
Check out the pics.
Alex
http://s461.photobucket.com/al...?albumview=slideshow
Thanks for noticing. It's been a hot and sweaty job here in Arkansas' weather. Hoping for 500-550 HP. Will video startup if I can. Will keep you posted. Thanks again, Alex
Originally posted by tajon:
that looks awesome! great work. I can't wait to hear it run with that 427. What type of power do you expect?
