All,
2/21/21  ONE SET LEFT
I again have available for Goose owners, the proper paper air intake tubing for the connection of the Goose air cleaner to the rear air intakes! See picture.
aircleanerfab42
Also, I have the defroster tubing for the dash. If you missed the last batch I had, you missed the lower prices....even with the drop of the Euro to the dollar...the price went up by 30% by the supplier. These were shipped from Europe, which is also factored into the pricing. I could not locate this proper tubing any where in the US.
The rear hoses are a paper accordion tubing 80mm x 1000mm hose and the defrosters are, as found on my car, 1-30mm x about 50mm and 1-24mm x about 50mm hose with two pieces of 30mm taped to the ends....
Now, I have learned/heard that some cars got two pieces of 30mm hose, eliminating the patched up 24mm hose, but many, like mine, got the 24mm piece with the 30mm ends taped on and one 30mm hose.
It seems that the 24mm piece may have fit better on it's vertical run on one side of the heater box, but the 24mm hoses definitely do NOT fit the heater fittings at the lower air box OR the vents in the bottom of the dash! I tried..... so you do need to put the 30mm ends on with black tape.
I think it depends on when your car was built and with which dash configuration. I haven't seen enough late cars to know what is correct for them....so I'll present two pricing options:
1) Two rear hoses 80x1000mm, one 30mm defroster hose and one 24mm defroster hose= $175
2) Two rear hoses 80x1000mm, and two 30mm defroster hoses= $185
3) Two rear hoses 80x1000mm= $140
All prices are without shipping, you pay actual. I use Fed Ex and the USPS where it is cheaper.
If you want original.....this is how it was done.
I have limited amounts of the 24mm tubing left, so please contact me if you are reading this post some time after post date....to see what I have in stock yet.
Thanks for looking!
  • aircleanerfab42
OK, down to two sets of air cleaner hoses and the 24-25mm defroster hose left.  Not inclined to order more of these..... so if you are hanging on the edge....don't hang too much longer!
Two of the large hoses and a short length of the 25mm hose still $175 plus shipping in a new box.   The 30mm hose can be had from VW shops here in the US still.
Just to reiterate, the smaller hose was used on "some" cars with short 30mm end pieces taped to the smaller hose, for one side of the defroster.  Other side was 30mm the entire length.
Some cars came with 30mm hose squished into the tight side.......
Later cars with the AC unit up in the dash???? No idea.  No one has stepped forward to tell us how their defrosters are connected. Yet.
Cheers!
