73 L Pantera
Repainted about 6 years ago in its original color using Sikkens single stage paint. Paint is in very nice shape with depth and luster to the finish. This car is completely rust free. Very straight body with crisp clean lines. All factory seams and weld points are all in tact as it should be. Floors, rockers and sub frame all bone stock factory and rock solid. All suspension sanded, bead blasted Powder coated and painted. Front suspension bushings replaced with Poly bushings. Ball joints replaced where needed. New steering rack installed. Original Koni Coil overs removed, sanded/painted reinstalled.
Brake calipers removed, flushed and cleaned. Adjustable proportioning valve installed.
Strong running rebuilt 4 bolt main cobra jet 351C.(photo documented) Eldobrok intake, Holly carb, Ceramic headers leading to Anza exhaust.
ZF shifts smooth with no grinding in any gear.
Engine bay is highly detailed
New exhaust tips.
Campy wheels have new center caps and are mounted with Goodyear Eagle 225VR 15 in front, 255VR 15 in back.
New brake master cyl.
New Stainless braided brakes lines.
New clutch disc
New Clutch master cyl
New Clutch Slave cyl
New Weather stripping throughout
New upgraded radiator cooling fans
New brass window gears
New upgraded Alt. with internal voltage reg
Cooling fans rewired to take load off ignition switch.
Many other minor upgrades to improve safety and drivability.
I have clean Florida title in my name
Car is located in Ft. Myers Florida
Priced at $72,500
PM or call Jay at 239 728-4051
  • 73_Pantera_cropped_550LR_1677
