...Damn Good Question!
The Internationally Recognized Designator for a Left-Hand Thread, is a Groove Cut All The Way Around the CENTER of the Nut.
I just went out and Checked on 'MY' Kat...it was the Nut Towards the REAR of the Pantera.
So...Wrench it CLOCKWISE as if to TIGHTEN (a Right-Hand Thread), and the Left-Hand Thread will come LOOSE!
here is a photo I took this AM (I have been blocked from site till now).
I worked a lot of turnbuckles so I could see (and know) which thread was LH before I tried.
besides the marked nut, It appears the shorter rod is the one threaded LH for mine
the manufactor I worked for did not used international designation as the LH nuts on the linkage I worked for 40 years were not ORIGINALLY marked. (they were after I adjusted)
AND if my access capibility continues, I wont be able to see my post
  • shift_link_001
I believe it does.
I know a loose trunion bushing will result in the ZF popping out of gear....
I believe lower is better, but I have only adjusted one of them...
UPDATE...
PS.... After reading Bosswrench's reply below, I did want to update this post. I agree with him that the only way you can do this adjustment is if all the shifter linkage is removed from the car, and then you soak the nuts / threads in Liquid Wrench or equivalent, and use vices, and big wrenches to get the 40 year old connections apart.
I was not able to break any of the nuts or the turnbuckles loose with the linkage connected in my car - I just slid the U-Joints on the splines shafts....
Brother-bee, when you start fooling with the shift-shaft trunnion, there are a number of clearance areas you need to watch simultaneously. There's a channel in the left motormount that the shift rod slides through with little clearance, and an adjustment coupler that gets very close to the edge of the inner rear fender on one side and the bellhousing on the other. Plus, when the height of the trunnion is changed very much, the total length of the dog-legged shift-shaft also changes, which can cause popping out of gear if some are selected. These maladies can accompany a bad rubber isolator in a motormount, too, making diagnosis complicated.
If the trunnion is loose of course, you really have no choice but to adjust it, and the length change can be adjusted for quite a bit using the splined end of the last u-joint rather than loosening the big adjuster. On our car, I was never able to loosen that adjuster- it takes ZF removal to get big enough wrenches in there, and so far, I've always forgotten when the box was out. Finally, if you have one, be very careful with the popular aftermarket aluminum-and-teflon trunnions. That area gets awful hot while running and teflon softens at low temperatures. The teflon bushing sometimes softens enough to slide past its setscrew and out of position, suddenly making shifting very difficult. Very hard to repair on the road with a smoking-hot engine.
