well..if all new..
1) did spread oil via the uncovered heads to lubricate the rocker and springs etc
2) did use a drill with 1/4 extension to build up oil pressure (I taped the nut to NOT LOOSE IT!!!). Is a known practice where you access the pump via the opening from the distributor... You might turn the crank after a while to get a different position for the lifters and may be the bearing/holes. Does work even if engine is already in the car.
Matthias
I use an accusump pre oiler Plumbed into the oil pressure sender oriface. I also have a line from that location to the oriface adjacent the oil filter. I have a one way check valve in that line that prevents flow from the accusump & oil sensor location to the oriface adjacent the oil pump. I love starting the engine after my oil pump pressure gauge reads 10 lbs.
