The plastic knob has a threaded metal insert pressed in (or cast in). Someone probably added Lock-tite to keep vibration from moving the knob and spoiling the logo alignment. If the knob moves, the insert is likely bonded and you've managed to rotate the vinyl-wrapped plastic on its insert. I would leave it alone or you WILL wreck it.
