These have driven me crazy. Spent many hours, and many quarts of brake fluid before knowing that they were there, both in SS brake lines, and clutch line. Got them from a vendor. Every time I think it couldn't be that stupid little ball that is causing me so much trouble in bleeding, there it is again. What the heck is it for, and who is crazy enough to put a HOLE in a brake/clutch line?!
The question is how do you seal the darn thing off? On some of the fittings I am using you can flip them around and that will work, others you can't.
  • DSC00043
Using a circular pin to hold the nut in place is common practice in AN hose ends (fittings). It acts like an internal snap ring and has nothing to do with the seal.
Typical AN hose ends and AN fitting adapters are 37° flare and should not be mixed with industrial 37° flare fittings or anything else. AN 37° flare and industrial 37° flare fittings function identically. In many cases they appear to be functionally interchangeable, but they are not.
The sealing happens between the male 37° flare of the AN adapter fitting and the female flare inside of the AN hose end. These are carefully engineered to work together.
If your assemblies are leaking it can be caused by several things like mismatched fittings (don't assume that a vendor is selling compatible parts), dirt between the sealing surfaces (doesn't take much) or the assemblies have been over tightened.
It's prudent to buy all parts for the assembly made by the same manufacture like Earl's (now Holley I believe), Fragola Performance Systems or any other reputable manufacturer. Then you don't have to worry about compatibility. You can mix an match between brands but do your homework. Don't assume that a vendor selling a car specific kit has it right. Ask what brand the parts are in the kit. If they don't know or won't say, go elsewhere. Plumbing issues can be deadly (brakes) or dangerous (fuel).
