Evening / morning all, depending on where you are.
I'm getting down to changing the race spec Goose back to (or rather toward) road / stock. The previous owner was 6'1" and decided to lower the floor on drivers side (only) to fit more easily with a helmet on. On a smooth as glass racetrack not much of an issue, but when I was in Sicily it bottomed out A LOT, so time to change!
The help I need is guidance as to what it should look like. The passenger side (LHD car) doesn't seem to have been messed around with and consists of a long  brace / cross member (front to rear) underneath and 2 x cross side braces inside. (attached)
Is that correct?
Does anyone have any photos of their car or a car from below and / or without carpet?
I'm assuming that the passenger and driver configuration are the same ?
any other comments gratefully received
cheers
  • Image-1
  • Image-1
V8jet, thanks for the great account of your adventure the other day, that was a brave move, hat's off for getting the Goose out and representing DeT so well!!
Had a pic of my LH (driver's side) floor pan that replicated 1010's heavily rusted original, showing where the stiffening ribs go.  Floating nuts for the seat are in the lower 2 ribs so that defines where they need be located (nuts fall on the approximate center line of those ribs).  The ribs themselves taper down in height,  c. 24mm tall at the backbone, and c. 14mm at the sills.  This compensates for the fact that the L & R floorpans aren't planar, but instead slope slightly downward toward the center of the car.  Thickness was 1.5mm.
The passenger side is functionally identical although narrower by about 2" IIRC.  The biggest dangers seemed to be getting the seat mounts in the wrong place.  The floating nuts don't provide much movement and if the seat tracks end up even slightly cattywompus (ie non-parallel) the seats won't slide well, making their installation and removal a HUGE pain.  There is minimal clearance for the passenger seat - on either side of the seat, at least with the late 1 piece buckets - so correct placement of those mounts is critical!
Pic 2 shows the long stiffeners, which are c. 12mm tall only. The 'box' section was ~43mm wide.
Pics 3 and 4 are different cars....note how the location of the driver's seat is biased substantially toward the sill.  This image is from an early car so I'm relatively sure all cars were like this, not just the 2-light cars that had a headlamp lift lever to accommodate.   As shown in pic 4, the floorpans rest on top of the flange running the length of the backbone.  Finally, comparing pics 2 and 4, I can only conclude that the exact location of long stiffeners must have varied somewhat car to car!
Images (4)
  • Floorpan LH with inner sill added
  • underside
  • 8MA6XX
  • 8MA7XX
