Following are some photos and explanation of how I built a replica of the original air cleaner that was missing from my car.  There were two different designs used by DeTomaso, this is referred to as the oval snout by most people.
I started with a stock 302 air cleaner that I think was on a ford ranchero originally. The 2 barrel version works best and still fits the 4 barrel carb. I cut off the gutter area at the bottom of the housing and replaced it with a flat piece of sheet metal to replicate the original dimensions
3581B3B2-B14D-433F-82C9-3F541028CEAA
D3B7B246-9126-4836-9E8B-C534B10EFCF0
The welds were stitched to prevent warping and welded only on the inside, but built up rather thick to allow for shaping from the outside later.
To get the proper radius on the bottom of the housing, I ground the welds down from the outside :
A0BAB897-2AB8-4E4E-894B-C008D1C58E1B579FE673-403D-460C-B9A5-637E9E952F57
I then made a buck for shaping the the spouts from a block of hardwood (walnut):
DCAEA3E0-C7C0-4DD6-824C-6BDE63ECFC5E
12F55340-2BB4-43C3-BA65-00DFFC8BFFD4
73608E49-DF5E-4AD5-B20C-50D1F52553FF
8C6182D3-A0F9-426D-A7D3-B8D571CF0A2EBE166D04-B0DE-4BA4-9B0D-8EF5B48AAE6C
DeTomaso made the snouts as two piece pressed units that were spot welded together. Rather than take the time and money to make a die to press the metal into shape, I hammer formed the metal over the buck, stopping to occasionally anneal and shrink the metal:
6AB6FDE0-2DB4-4EEC-BCEA-41D17A1B0EFFCFFEA843-7871-4AE9-93A0-A2CF0374133CA8695833-621B-4F72-8877-767D6AF0F534
The four halves were then trimmed to fit and overlapped for spot welding:
2E3E764F-7802-4812-9136-D8E1D1D34F63FEAA74D1-BC54-4D84-9E73-D2A1ADC6536B
The snouts were then installed in the housing and the edges flared for welding from the inside only:
8140AE0F-6785-48F3-A140-0ADB216C5882
F1ADA63E-A388-4CD8-A84E-AE79F38981D8
The hose fitting was carefully removed and repositioned to the front of the housing for welding:
1D18E5C0-2211-475F-9911-EFAB8443D6D2
The finished product was bead blasted in preparation for painting:
D9100F58-BBE3-4F7B-899B-87557DE0D423
4FA52164-92BA-4B39-8890-D4C037290E7F
With the addition of a little filler and some wrinkle finish paint, it looks like this:
1DDE8FB6-8CA1-4599-93CD-40A7097D5766
AF0A4DCD-3F1E-4C90-8B61-59AB12DAAAEE
With a proper sized air cleaner element, the lid fits properly, unlike the photo above.
It turned out to be a much bigger job than I thought, but other than the lid, which is slightly different shape than the original,   it looks correct to me.  What do you think?
Images (22)
  • 3581B3B2-B14D-433F-82C9-3F541028CEAA
  • D3B7B246-9126-4836-9E8B-C534B10EFCF0
  • A0BAB897-2AB8-4E4E-894B-C008D1C58E1B
  • 579FE673-403D-460C-B9A5-637E9E952F57
  • DCAEA3E0-C7C0-4DD6-824C-6BDE63ECFC5E
  • 12F55340-2BB4-43C3-BA65-00DFFC8BFFD4
  • 8C6182D3-A0F9-426D-A7D3-B8D571CF0A2E
  • BE166D04-B0DE-4BA4-9B0D-8EF5B48AAE6C
  • 6AB6FDE0-2DB4-4EEC-BCEA-41D17A1B0EFF
  • CFFEA843-7871-4AE9-93A0-A2CF0374133C
  • A8695833-621B-4F72-8877-767D6AF0F534
  • 2E3E764F-7802-4812-9136-D8E1D1D34F63
  • FEAA74D1-BC54-4D84-9E73-D2A1ADC6536B
  • 8140AE0F-6785-48F3-A140-0ADB216C5882
  • F1ADA63E-A388-4CD8-A84E-AE79F38981D8
  • 1D18E5C0-2211-475F-9911-EFAB8443D6D2
  • D9100F58-BBE3-4F7B-899B-87557DE0D423
  • 81A5A7A1-1C3A-42C6-9BC4-FFD025FA1513
  • 4FA52164-92BA-4B39-8890-D4C037290E7F
  • 1DDE8FB6-8CA1-4599-93CD-40A7097D5766
  • AF0A4DCD-3F1E-4C90-8B61-59AB12DAAAEE
  • 73608E49-DF5E-4AD5-B20C-50D1F52553FF
