You can buy foam sheet from motorcycle retailers or online, look for UNI-Filter in coarse. Although you don't say what Weber carbs you have, I'm not a fan of foam filters on Weber IDA due to the reversion soaking the filters in gas, so I only use fine steel mesh covers. There's a Group 4 Pantera video floating around at the moment where you can visibly see the reversion.
