I cobbled together this arrangement to test a booster.
IMG_4441
I checked my adapter, using my fingertip as a plug I can quickly and easily pull and hold 25 inches on the gauge.
Now, using it on the booster, after 20 or 30 seconds of vigorous pumping, I can barely get a reading of 6 or 7 inches, which then leaks off over the course of a minute or so.
I have determined the external check valve at my adapter connection is good. And, if I push on the brake plunger rod I can hear the release of the little bit of vacuum I pulled.
I should be able to pull more than 6-7 inches on this thing, right?
Rebuild or replace? Any favorite rebuilders come to mind?
  • IMG_4441
You may have trouble home-rebuilding it. Bendix-Italia does not sell parts thanks to a lawsuit decades ago by someone who bought a then-available repair kit, exceeded his skill level and wrecked his car while testing, then sued the company. Some Pantera vendors do sell a complete replacement.
There is another alternative: an adapted GM booster assembly from Bob Byars at Precision Pro-formance in CA. This booster is a dual-diaphragm type with a slightly larger OD so it gives more boost, has a two-stage aluminum master cylinder with integral keep-alive circuit and is a true bolt-in (being made in the U.S, it does needs 2 short new hydraulic lines with flared ends rather than Euro-style bubble flares).  I bought one in 2002 for our '72 and have had zero problems to date. It was also cheaper than the available replacement (for a series-308 Ferrari).  Bob warranties his conversion.
I checked my other 'spare' booster yesterday. It's even worse that the first, can't pull/hold anything at all. And, I confirmed the one in the project car is also junk. That makes three.
After seeing that, I thought I should check the one in my driver. I can only pull about 16~17 inches on that one that bleeds off over the course of about a minute and half. Brakes on that car seemed fine. I guess they could be better.
We will make some calls today.
Many times, it's a ruptured diaphragm. And this can come from motor oil being sucked into the booster from the intake connection past the plastic check valve on the booster. Oil seems to rot the rubber Bendix used. Some desperate owners have TEMPORARILY fixed a torn/punctured diaphragm with silicone rubber (after alcohol cleaning), but you need to give the goo time to cure before firing up the engine. And it WILL come loose eventually- probably when you most need it- hence "temporary".
In my experience, by the time you get the booster vacuum leak fixed,  the master cylinder will begin leaking fluid- if it is not already. 'New' is more dependable- either a Byars conversion or the more expensive Ferrari 308 unit.
Doing some follow up I find:
1. ABS Power Brake (CA) - says rebuild is $150, plating an extra $25.
2. Karp Power Brake supply (CA) says +/-$300 to rebuild, BUT, they say the Bonaldi booster diaphragms are presently unobtainium (unusually small diameter?). He is waiting on samples from a new vendor. Will advise in a week.
3. Harmon Classic Brakes (GA?) confirms diaphragm availability issue and advises that another part of these boosters very often breaks during the process and is unobtainium (Karps guy also warned about this, in case I wanted to try opening one up myself). Harmon won't even try them anymore.
4. John Stuart (Ontario, Canada) - wants me to send the master cylinder AND booster, he'd try and rebuild or he'll cobble together a substitute. Hmmm. $350-$400, better to use the Precision Proformance unit at that rate.
5. Power Brake Exchange (CA)- sent him a photo of the unit, he says he has parts and can rebuild. $180, and they'll plate it too.
Weird pricing on the plating. He says his guy will plate 10 to 100 lbs of parts, flat rate $150. I wonder if I could include some other things too?
6. Whitehorse Restorations/Ed Strain (OR)- one local guy with first hand experience, and one of the vendors above were less than lukewarm about these guys. Haven't called them yet.
I've got three boosters to rebuild, I think I'll send one off to ABS and see how they do and take it from there...
I swapped the generic clear tubing pictured above with Tygon fuel line.  It looked promising and then it began it fail.  The tubing seemed to sweat brake fluid.  I like clear tubing in this application because it shows fluid along with air bubbles.  The air bubbles can be removed  by simply un-mounting the reservoirs and holding them up high until the air bubbles go away.
I am hoping that the version of Tygon tubing for brake systems noted below resolves the issue.  I will report back if this chemical resistant version of Tygon corrects the problem with brake fluid sweating.
https://www.amazon.com/gp/prod...00?ie=UTF8&psc=1
In two of the three misbehaving boosters I had the issue turned out to be the seal at the MC pushrod. Both had aftermarket MCs with adapters that coincidently used a special seal common to both. Karp had them on hand.
Booster number three will pull good vacuum, but doesn't provide any assist. It will just have to wait for now.
Steve:  my 71 (1744) has the same clear plastic tubing.  It has discolored due to age.  It also "sweats" brake fluid all the time (PITA).  OBTW, the little plastic reservoirs are actually a VW part.  I bought two new ones as I was going to replace mine but have not done yet.  The fittings on the new ones does not have the correct tubing on the connect and requires some modifications.
To duplicate Bobby Byars GM conversion brake booster, the thing needs to be completely stripped and the stud pattern on the pedal side weld-converted from GM 3-stud SAE to a 4-stud metric to match DeTomaso's bolt pattern. Then reassembled and gold-alodined.
How Bobby did all this for the price he charged, I have no clue- and it had a warranty. The matched aluminum master cylinder was included.  Inside one MS port is a 'keep-alive' check valve about the size of a very thick nickel for the front calipers, I always remove those since I had such a valve stick, once upon a time.
Otherwise, the only thing to watch out for (in shipping) is the vulnerable plastic valve on the pedal side is not not damaged. I never asked what model of GM it came off of- sorry. Mostly just check the booster OD to be sure it fits under the Pantera hood; not much clearance and the GM is slightly larger. Good luck-.
I test drove a Pantera for someone not long ago and there was little if any vacuum to the brake booster.  The car had good brakes.  The brake pedal was quite firm and the calipers seemed to be working correctly.  The hydraulics seemed healthy.  Without power assist it took ample effort to slow the car and it took me by surprise how much the booster helps.  I think I could drive a car without power brakes but I would need to be prepared for that type of braking.  It's easy to try out.  Just disconnect the brake booster hose and cap off the manifold or carb.
I've tried running without a booster but found the pedal was just too heavy to be comfortable. I'm not saying it's not possible but with my calipers and CNC dual master setup, the pedal was just too heavy. I believe the root cause was that there isn't enough leverage with the Pantera's "short" brake pedal. With a longer pedal, such as SACC's aftermarket "racing" pedal setup, the pedal effort, without a booster, is reasonable.
I did not actually count the number of pumps that it took to get to 15 inches vacuum but it was a lot.  I continued to pump once it leveled out at 15 inches and did not get any more vacuum.  I am thinking there may be a leak.  My next step is to get the car warmed up and then check manifold vacuum with the booster connected and then with it disconnected and the manifold capped off.  The vacuum reading should not change.  If it increases with the booster disconnected then there's a leak.
