...And FYI, that Large Circular piece is used to support the BACKside of the Brake Rotor HUB, when Pressing Out Bearings and Cups. Never support upon the Outer Circumference 'Pad Surface'. If You do, the Pressure needed from a Hydraulic Press, WILL Break the Iron Rotor into Pieces. Just ask those who have done this.  MJ
