My never-ending project Pantera is exhibiting some strange sounds after we swapped out intake manifolds and installed a new EFI system. My setup is a 351W steel block bored and stroked to 383 with Edelbrock Victor Jr. aluminum heads an Edelbrock Performer RPM manifold and Holley Sniper EFI. I have 180 degree headers. I also installed a new thermostat in the correct orientation. Part of the job of installing a new intake manifold entailed draining about a half gallon or so of coolant so that we could safely remove the old intake manifold without dumping coolant into the motor valley.
I’m pretty sure that, due to my lack of Pantera experience, we’ve overfilled the cooling system. When we finished work, we added coolant back into the small tank. I run about 190-210 coolant temp after running the car and driving it for a while and after parking it at these temperatures I hear a pretty substantial boiling sound in the cooling system tanks. Water temp doesn’t get too high, and I don’t overheat, but I am barfing coolant out on the ground. The boiling sound continues until the engine cools down a bit.
My hunch here is that I have air trapped in the system. I need to bleed it, but I am admittedly having a bit of confusion as to the correct identification of the two coolant tanks as well as the proper procedure to bleed the system. I have the Hall Pantera giant lay-down radiator in the front and all stainless steel water lines. All fittings are tight and good. I am not dumping coolant into the oil or exhaust so there’s no head gasket issues.
Regarding the cooling tanks, I have a short tank toward the firewall and a taller tank toward the rear. There is a pressure relief cap on the short tank, and a normal cap on the tall tank. Which tank is which? Also, what is the correct procedure to follow when bleeding the system? Apologies if these questions have been asked before, but I was not able to locate much using the forum search (or google search)...You can see in the photo that I’m dumping coolant out of the tanks as well.
  • image
The "system tank" is the shorter of the two tanks, it has two 13/8 hoses attached to the side. It should be mounted closest to the engine. The upper hose (inlet) comes from the engine outlet, the lower hose (outlet) attaches to the plumbing that feeds the radiator. That's the tank that should be equipped with a 13 psi radiator cap. This tank serves no other purpose other than to be a convenient place to locate the radiator cap.
The taller tank acts as the coolant recovery tank. There are no connections for the larger 13/8 hoses. The overflow hose from the filler neck of the "system  tank" connects to the bottom of this recovery tank. The cap for this tank should allow the tank to be vented to atmosphere.
If the cooling system lacks the "head tank revision" as detailed in Chuck's (Rocky's) drawing, then the left hand tank of the radiator should have a petcock screwed into the fitting located in the top of the tank, making it possible for you to vent air from the radiator manually.
Start the engine, keep the recovery tank half full, leave the cap off. Turn the cabin heater on for full heat (this purges air from the heater core).  Once the engine reaches operating temp raising the front of the car will help any air in the engine or the plumbing downstream of the engine to flow towards the radiator; then raising the rear of the car will help any air in the radiator outlet flow towards the engine; then raising the front of the car again shall help any remaining air flow towards the radiator. At this point all the air in the system should be in the top of the radiator, opening the petcock in the top of the left hand radiator tank should allow that air to flow out.
Keep the level of the recovery tank about 1/2 full when the engine has cooled to ambient temperature.
P.S. whimsical note from the forum admin. You did an excellent job titling the topic and selecting the forum!
@George P Just to clarify, am I supposed to raise and lower the car at either end as directed, with the engine running? Or can this be done with the engine off after coolant has reached 160-170F? I'm pretty OCD about shop safety and the idea of lifting the car on a floor jack while it's running doesn't feel "right" to me, even with the large rubber wheel blocks I use. But hey, if this is the way it's done, then I'll do it. I just want to be absolutely sure, as it's a sizeable investment I have in this car on just the purchase price alone, not to mention the current work done and future changes I plan on making to the car.
Regarding the topic title and forum selection, I noticed that a couple of my past posts have been modified, so I figured there was a specific format we're supposed to adhere to.
Thank you (and to everyone else responding) for your responses to my incessant questions regarding this car. While I'm fairly mechanically inclined and have done all of the major work on my Shelby GT500 and Focus RS, the Pantera is a substantially different animal (pun intended) than what I'm used to.
yes, leave the engine running, keep the coolant circulating, and the air along with it.
I normally leave the pressure cap off the system tank, and watch the coolant level in the tank. If it decreases I'll top it off, but at some point (when the thermostat opens) the coolant will begin overflowing the tank. At that point I screw the pressure cap on. At that point I also know that the thermostat has opened, and that it is time to raise the front of the car for the first time.
By all means keep at least one tire chocked on both sides, to prevent the car from rolling forwards or backwards.
running cat
Click on the link to "my Pantera's photo page" and read my notes near the bottom regarding the coolant system. Pay attention to the part about the plumbing between the radiator outlet and the coolant pump inlet.
  • running cat
DSC00012_[1)...It is My Opinion, Air in the System is Not Your Problem! Your Problem is, The 'Radiator' cap is NOT holding the PRESSURE. Not even close! I Run a 16 LB Cap. I've never done the 'raise the front, raise the rear'. Never had to. I just bleed the air out, at the Top Left corner of the Radiator. Nor, have I done the 'Hosed System Re-Route', Modification.
Most important is to have the 'Pressure Tank' (the Short One) Raised up Higher, with the Top Most Level of Coolant 3 Inches Higher than the Top of the Valve covers (See in Pic). This gives a 'Highest Chamber' for All air to Accumulate. And where the Air will be 'Burped-Out' into the Recovery tank, BEFORE the coolant. Then Upon Cooling Down, the Correct Cap is Designed to Allow a Reverse Flow of Coolant from the Recovery Tank Back into the Pressure Tank...FREE of Air.
If I should open the Cap on the Short Tank...When all is Cold, Coolant spills-Out, as there is NO Air in the Tank, at all, Because the Recovery system from the Over-Flow Tank, is working Perfectly. The Caps on Your Tanks May Not Do This.
The Sounds You are Hearing are Coolant Boiling into STEAM, because the System can Not hold the Pressure, which would PREVENT This from Happening. Last...all that 'Mud' spilling out of the CAP, Should Tell  You, the System needs a Complete 'Flush-Out'. And then, get some 'Anti-Boil' mixed in Distilled Water (NOT DE-Ionized Water!) 50%-50%. I do a Ratio of Aprox. 40% Glycol-60% Water.
MJ
P.S. Double Clamp Every Hose End, Just a Recommendation, this will save You a lot of Heartache in the Future.
  • DSC00012_(1): Beyond Boss 351 A Lot of Tricks in There.
