Fuel pump is shot. No marking on it (perhaps filed off pre-chroming?).  If not made anymore (which is likely), what would be the best replacement?  Current fuel lines appear to be 5/16, but appears most newer pumps are at least 3/8, so I assume all the fuel lines will need to be replaced as well. Thank you as always for the advice in advance.
F4EBB393-E5EA-4A97-A573-8DBA99E1D4D0
  • F4EBB393-E5EA-4A97-A573-8DBA99E1D4D0
