Mine turned out to be blown amp gauge.  Car is original and had like yours a charged battery prior to going out for the ride.  Ended up changing to the Hall Voltmeter, no issues since.   As I will be upgrading the alternator, I think it was a good choice - time will tell.  Rodents would be the next cord chewing offenders.....
Images (3)
  • mceclip0
  • mceclip0
  • mceclip1
69B1E946-3508-4985-9BED-456382BFFD23NOT RIVETS‼️‼️
 What you are looking at are stubs of the factory installed security bolts. The bolt heads are designed to snap off when proper torque is reached. Easiest removal process seems to be using a cut off wheel on a Dremel handpiece to cut a slot in the remaining stubs. At that point a flat blade screwdriver usually does the trick quite easily.
  • 69B1E946-3508-4985-9BED-456382BFFD23
