Yes that was not a very good picture.  Here are some others.  The knob turns like an on/off volume knob.  One direction it clicks off, the other degrees of ‘on’ it seems.  Wiring goes inside the steering column but might exit on the other side in an area i cannot easily see.  Will have to research more this weekend as it is not obvious.
  • C5A06B14-60E9-4A2C-BADA-312207A53116
  • EBC1881E-C9BA-4ED0-8502-85913DFFF7CF
lf-tp2511 posted:
 Stock windshield wipers only had two speeds. There are aftermarket controls to make your windshield wiper a variable speed. Can you  please turn on your windshield wipers and then see if that knob has any effect on them.
 Just a stab in the dark but at this point the best I can do.
Excellent suggestion!
