Originally posted by The Pope:
Mr. Melton is a real peach. Too bad interested buyers cannot get access!
Good luck with your sale.
As I understood you only need to be a member to access the database, the Cars for Sale listings are open viewing for all. Whether you agree with the Provamo access format or not Chuck has to be the cheapest advertizing around!
My intro for the ad:
#5606 has been maintained by Ralph Suarez, (San Diego Pantera Club officer) who lives nearby. The vehicle has about 78500 miles on it. #5606 was sold new in Los Angeles and is rust free and numbers matching. I have a Marti report for the vehicle.
#5606 has factory 15" wheels, 8 and 10 width with near new (less then 1000 miles) Toyo tires on it. I just renewed the California registration this month. The car is "dialed in" and runs beautifully and reliably. The car includes factory service manuals, and factory Service bulletins. I have the sun visors, wiper blades, engine cover trim pieces, rear tub (in great shape) front license plate bracket, owners manual, extra brake rotors, spare ZF gaskets and a new collapsible spare to go with the vehicle. Tom Tajaarda autographed a book of Pantera test drive reviews for me. There are some miscellaneous other items to go with the car that escape my memory right now.
I believe the vehicle to be accident free. I walked around it with a magnet and everywhere I touched the vehicle with it, the magnet stuck.
The A/C works beautifully and blows cold. All lights, turn signals, etc. work.
PRICE: $43000
NOTE: The description of the vehicle needs to reflect the new Toyo Proxes 4's and ST's that I put on the vehicle less then 1000 miles ago.
I hope this helps:
Here is the salient information that I provided to Chuck. This is from the flyer of the second owner of #5606. (I bought #5606 in October of 2008.) He owned the vehicle for 29 years. He bought it from the 1st owner who was an executive at Paramount Movie Studios.
Engine: 351 C 4v
Rebuilt 1984
Engine balanced
Bored 30 over
Block decked and line bored
Bronze freeze plugs
New TRW pistons
Chrome molly rings
Rods polished and shot peed, heavy duty rod bolts
Crank ground 10-10 Tuffrided and oil holes chamfered, heat treated, oil resistor plugs.
ISKY cam
Cloyes True roller double row timing chain, steel sprocket gears
High volume oil pumps
10 quart oil pan, windage tray
Hall Pantera high tork starter
Aluminum high flow water pump
Holly high performance fuel pump
Heavy duty inline filters
Edalbrock manifold
Holly 750 dual feed carburetor
Neophalactic carb spacer
Inline fuel pressure gauge
Ford Dura-Spark Distributor/MSO system
Stainless steel braided lines.
Heads
Magna fluxed, resurfaced
Milled to accept screw in studs 5/16
Manley guided plates
3/8 Pushrods, hardened tips
Heavy duty springs, chrome molly retainers
Roller rockers
Stainless steel valves Teflon coated bronze valve guides
Hardened valve seats
Chrome valve covers.
Exterior Trim
Painted 1995, shows well
All exterior trim powder coated
Aluminum side markers
Aluminum door handles
New glass windshield and rear window
New rubber seals, door, front trunk, rear trunk and stops
New carpet, trunk and tray
New side view mirrors
New emblems
Splash shields, powder coated, new rubber moldings
Hall Pantera hood vents
8-Inch front Campy, 10 inch rear Campy, 205 BF Goodrich , 305 BF Goodrich tires, approximately 5,000 miles.
Interior
New interior
Hall Pantera A/C and heating system. A/C condenser moved forward. New fan, heater valve, Neoprem hoses, rotary pump
New rubber pads to clutch and brake pedals
New aluminum accelerator pedal assembly and cable
Overhead speaker system
Alpine radio, setup for Sirius satellite radio, I-pod
Billed aluminum – shift handle, seat handles
Seat rollers replaced with bronze units
Hall Pantera replacement foam to seats
Dash recovered
Hall Pantera center counsel
New Bosh window switches
Bronze window gears
New window felts
New turn signal assembly
New Sparco steering wheel assembly
New carpet to front and rear trunks.
Cooling System
Hall Pantera Phoenix radiator
New fan sensors
Two sucker fans, new
Stainless steel water tubes and pressure tank, overflow tank
New Neoprem hosing
Aluminum cap.
Transmission
In good condition
Aluminum flywheel
Hay’s diaphragm pressure plate panel clutch, throw out bearing
New slave cylinder stainless line and braided hoses
Stainless steel vent tube
Rebuilt half shafts
New speed gear seals
New speedometer cable
Billet aluminum trunion bearing.
Suspension
New upper and lower ball joints
New Neoprem bushings
New Neoprem motor mounts
Rebuilt brake system, stainless steel braided brake line
New wheel bearing front and rear
New upgraded Hall Pantera master cylinder and brake lines
New brake light sending unit
New Hall Pantera heavy duty rear sway bar, billet aluminum brackets
Original rear sway moved to front of car
Bronze spacer to rack and pinion steering
New rack and pinion rubber boots
New Koni shocks
Spacers removed from springs
Billet aluminum wheel housing camber bar
Suspension powder coated
Precision Pro-Performance rigged suspension kit installed.
I am selling #5606 because over the last couple of years, the arthritis in my cervical spine has gotten progressively worse and it is too uncomfortable to drive the car any great distance.
I am planning on replacing the Cat with a vehicle that is more benign, easier to live with.
The most likely replacemement is a 2011-2012 Ford Mustang Shelby GT500.
