Selling the AeroQuip braided AC lines (red Fabric not stainless) I pulled off of my car. Everything is in good working order, held pressure just fine. Was doing a bunch of cooling system work on the Pantera this winter and decided it was the perfect time to go to a front mount condensor.
Hoses are in good shape, no chaffing or holes in fabric overwrap (except for one tiny spot where the fabric is just beginning to fray on one hose). Hoses are dirty though, dont expect brand new looking hoses. May clean up nice, I have no idea.
Hoses are for R12 (Flare connections), route is from compressor to condensor in factory location, filter drier to evap. thru the passenger side rocker panel, and then evap. to compressor thru the passenger rocker. The condenser to drier hose is a normal AC hose, its rubber coating has been worn away in one area by the trunk tub. Inner liner is still good, I wouldnt use it though. Will send with other lines so you can use it as a pattern.
Will sell for Best Offer.
Dave
