Where would one source a new one drilled for a Centerfoce pressure plate?
Centerforce. Although they're not cheap! Just over $700 if I recall correctly.
A number of folks on the DT Mail List bought Fidanza Aluminum flywheels a year or so ago for about half the cost of a Centerforce flywheel, then they just had them drilled for the Centerforce pressure plate bolt pattern.
http://www.fidanza.com/aluminum-flywheels.aspx
http://www.amazon.com/Fidanza-...wheels/dp/B000ECTPTQ
The price varies a lot on Aluminum flywheels because they are not all built the same (extruded vs. forged etc.) nor of the same alloys and different SFI ratings.
It is worth checking into what you are getting for your money; Fidanza are usually 6061-T6 and Centerforce 7075-T6
