Here's what's happening. This season alone I've broken 3 sets of muffler hangers and not the rubber ones that came with the car but strong aftermarket hangars. I've broken 2 or 3 trunk hinges, both the part that bolts to the trunk lid as well as the mechanical hinge on the bottom that bolts to the body. I am using the later versions that have a thicker zinc plated metal. The corners of my trunk lids as well as the corners of the body by those corners are making contact and chipping. It would seem that the back of my car is moving considerably under load. Has anyone else here had this problem before and is there a recommendation outside of keep replacing parts? If the answer is just use better parts, I'm okay with that. Can some one tell me what parts they use? Thanks all.
