Well I spent about 6 hours making  really nice mounting plate and am very happy with it. Then I noticed in the instructions that this is only to be used with 6 Series ignition systems which I don't have.
And I can't return it because I opened the bag of parts.
Anyone need a nice aluminum mounting plate?
AND I bumped the A/C hose and made Freon leak out.
Really hasn't been a good week for me.
Sure, give it a try, especially if you can’t return it.
You may find that if you are running a ballast resistor, the coil doesn’t fully charge at high RPM. This can result in a high RPM misfire.
This happened to me with a Ford TFI (solid body) coil.
Check the instructions.  If it shows no ballast resistor in the circuit, you can probably keep yours in, until you know you have a problem….  That’s the safe way to do it.
@jmardy posted:
Post a pic of the mounting plate you made.  We'd love to see it!
As others have already pointed out, for 6-series ignition, that's an MSD "instruction" to get you to buy more of their products.  This is the recommended 'best' coil for use with the Pantera Electronics EIS.
