Fuel pump is shot. No marking on it (perhaps filed off pre-chroming?). If not made anymore (which is likely), what would be the best replacement? Current fuel lines appear to be 5/16, but appears most newer pumps are at least 3/8, so I assume all the fuel lines will need to be replaced as well. Thank you as always for the advice in advance.
