Anybody have any recomendations on the little wheel/dolly things so you can roll/move a pantera that is snuggled in the heated garge for a long midwest winter?
AJThree. This is the hot setup.......I have a set of "Roll Masters" from a company called NMW out of NJ. They are basically very low profile heavy guage steel boxes on wheels/dollies. They allow me to set the car's tires in to the boxes and push the car around with minimal effort. But the really useful thing is that you can place your Jack Stands into the center of each box and then place the car down on top of the jack stands. Now you can have your car up on stands for the winter AND roll it around for your needs. In a tight garage this makes all the difference in the world. Good luck.....Doug.H
