I use a thin coating of Permatex Super 300 Form-a-Gasket Sealant. Permatex makes several types of Form-a-Gasket. the Super 300 is a non-hardening sealant designed to resist heat transfer fluids such as oil or antifreeze. I use it on cork and paper type gaskets that are not taken apart on regular basis. Put it on very thin.
I'd planned on using a smear of copper slip on the threads however, I was going to use some sealant as I believe one or more of the bolts tap into a waterjacket!
Phil, stainless fastners can corrode, thats why they are called "stain....less". If they are not of high quality metal it can happen sooner. A coat of antiseize on the bolt shanks wont hurt. Jeff
