I need a (2) door latch rod (?).
Actually I need a couple of the shorter rods with plastic blocks on each end that hold the ball. One rod per door. They connect the door lock to the next part.
In one book (repair manual) the part is 22152 - door latch actuator rod, and on Wilks site it is "Rod Outside door handle (R&L)"
His photo only shows ONE plastic connector per piece. But the rod should have one on each end.
Anyone ?
