Hi all
Not sure if this has been covered but did a search across the next and came up with a few results
Looking at buying a 71-74 next year and looking at the options for more power
Has anyone seen a LS3 fitted to a Pantera
I found a adaptor for the gear box so thats pretty easy and the engine mounts don't look to hard to make
Superchargers for the LS3 are a bolt on and the manifold can be spun around and bolted back on
600Hp with cam and super charger is easy on a stock motor and more with some interanl mods
The ZF trans in good condition will take it but I read one thread about using a Audi transaxle 6 speed box but didn't find any install pics although found picks of the box
From a few checks the engine would need to be moved back a little to line up with the current ZF output shafts
Second hand the boxes are much cheaper than ZF and you can set up a flapply paddle shift for it too
Any thoughts or info on whether this has already been done appreciated
