Hi Modok,
Congratulations on your acquisition, the bug to 'make it yours' has already started I see
You are aware that the '74 bumper and the bumperettes are quite different in the way they are attached to the car, yes? The '74 is an impact bumper with shocks that protrude through the body, plus a couple bolts at the outer fender, wheras the bumperettes bolt on. Unfortunately none of the holes line up betwwen the two for a direct swap, so you may be left with some cosmetic work to do as well. Sorry for rambling if you already knew this.
Good luck with the new P car, hope to see you one of these days at one of the NorCal or NV events.
