I was talking with Larry Stock (Pantera Parts Connection) Friday night in Monterey. He is looking for a grill also. He says they have become very scarce and are now made of 'unobtainium'. If you still have your grill, find a good chrome/polishing shop and see if they have a metal man that can hammer,bend,tweak yours back into shape. A good metal man can work wonders. Be aware that the early ones mounted with studs welded to the frame with nuts mounted from the inside. The later ones mounted with sheet metal screws through holes in the grill frame. They will interchange as far as size goes.
Good luck.
