The yellow and black wire in the picture below was pulled off the fuse panel decades ago. I need to reattach it to the panel. It likely belongs on fuse #7 (the first blue fuse below the white ones). As you can see in the picture, there is an open spade terminal at fuse #7. The wiring on Pushbutton car is different than later Panteras. I am hoping that someone with a similar car can look at their panel and confirm the location of the yellow and black wire.
