My GEN light has started coming on as soon as I start the car. I am totally new to the Pantera so I'm reaching out to the group. The only change is I noticed the hot wire to the electric choke had been cut or broke (looked cut)I have reconnected it and that is about when I noticed the light. Not assuming the two are related. Any thoughts?
Gavin,
One other thing to check is a faulty voltage regulator. It's located on the firewall and can be replaced by a $25 part from Canadian Tire (or even a Ford dealer if you have one that isn't totally stupid about not having a current part number).
When mine packed-up it also put a slow drain on (and thus flattened) the battery — which would not show up if you have (likely) a cut-off switch. If you have current on that wire when the key is off, change the regulator.
Good luck!
Mark
