I am hoping that one of you fellow Pantera owners might be able to help me. I have a 1974 Pantera and am in need of a part for the head light motor assembly. I need the little 6 tooth gear that engages with the larger gear attached to the bar connecting the two head lights together. This gear is visible behind the radiator where you adjust the limit switches. Do any of you know where I can pick up this item? I would also be willing to buy a complete headlight motor assembly, working or not, just as long as its complete. My email address is gunkits@pacbell.net. Thank you
