peter korosi posted:
i would like to get rid off so called "frog eye" head lights for a double low profile look any suggestion better than sacc solution
Hi Peter,  What specifically don't you like about the SACC lights?  Kirk Evans (Amerisport) sells a similar headlight conversion; I think it's nearly identical to the SACC conversion, but I believe Amerisport offers a 90mm and a 60mm conversion.  Do you have something in particular in mind that you're looking for?   Vader also used to sell a headlight conversion similar to Amerisport and SACC, as well as a single rectangular headlight conversion.
There are, I’m sure, only a handful of well engineered solutions out there. I installed the Amerisport lights on my late ‘71 car before I sold it. Great kit, easy to install and I was extremely pleased with the results — both aesthetically and light output.
  • CD0C79FF-8CFF-4C48-AF94-704B45124624
I have both 90mm and 60mm versions of Kirk's kits and the light output is amazing. The more modern 60mm I thought suited my GT5 a lot better. I got my first set from Kirk at a Vegas Fun Rally when they were a relatively new product to market, that said I still think they are the best aesthetically with composite formed housings over the SACC or Vader metal pieces.
With the recent growth of LED lighting you really can do whatever you want these days, it's more a matter of choosing how wide you want the opening height to be and finding a light unit that fits.
