i'm missing a header-heads bolt , does anybody knows the type ? i suppose it isn't metric
quote:Originally posted by 4V & Proud:
thread size is 3/8"-16
you may want to investigate whether the rest of your bolts are long enough?
if they're not utilizing most of the depth of the hole they'll all be excusing themselves
quote:The ORIGINAL header bolts on these cars were specially made for Detomaso.
They are SAE 3/8-16 threads but the bolt heads are METRIC!
Of course you can use regular header bolts that are cheap from just about anyone. Mr.Gasket for instance.
quote:Originally posted by Belgiumbarry:
Yes, normaly we use brass nuts on exhausts... they never get stuck due heat cycles ....
quote:Garth: I'm not sure where the original bolts were made but the point was there was no indication that the heads were metric at all.
