Originally posted by Fredrik Gustavsson:
Come on guys lets talk about headers!
What type do you use?
Where did you get them?
What about quality?
Did they fit properly?
If you have some negative experience with your headers and don't want to upset people when writing to this forum you can send your answer to me directly (fredrik at kommevalla.se)
"PI" Big Tubes, ceramic coated, big exhaust pipes, twin glass packs with crome tips and the cross over pipe connecting the two sides together. No fit problem with either cast iron closed chamber 4V heads or CHI aluminum 2V heads. The pipes are a little close to the frame but they will clear. I had a set of Hall's big bores, but they don't compare to the "PI Headers".
