Husker I will have to get back to you, it is still in the car and it has been raining. Sounds silly but I don't want to pull the car out of the garage until it dries up a bit.
Hey, I think I fixed it. Pulled it apart, cleaned the contacts and tested it. Seems to work just fine. You know, until I get it re-installed and it stops working again
Jay, Just for future reference. I sometimes use a modern style cube relay from NAPA. Try a headlamp relay for a 90 something Blazer. These are black plastic sealed. With 4 terminals. They are NO but there are others that have both NO and Norm Closed contacts. Bill 1362
