I have one I can measure for you but not clear what you are looking for.Are you trying to determine how tall it is and if it will fit under the stock engine cover? If so,from the top of the carb to the UNDERSIDE of the top of the air cleaner,it is 2 and 9/16 inches.From the top of the carb to the top of the whole unit it is 2 and 3/4 of an inch.The other possibility is from the top of the carb and then out sideways to the edge of the bottom of one of the filter elements it is 4 inches.Lastly it is a 1 and 3/4 drop from the top of the carb to the bottom of the filter elements. Hope this helps.
