4280 had no hoses w a 90 degree bend originally. i used hoses with a molded elbow at the fire wall. cut close and routed left hose above right on the steel tubes then parallel under the a/c compressor.these are available in gates and dayco with a leg @ 8 '' long and lengths @36'' to 48''. they also have a variety of short molded hoses if needed to make hose connections easier at the evap.
